To those of you that have this card (the model with the TV tuner):
1. How much and where to get it?
2. Does the card encode audio on-board or does it require a separate sound card?
3. Can the card capture in AVI format?
4. Are the MPEG-1 and MPEG-2 files it creates ready to be burnt onto a CD/DVD without further processing?
TIA....
1) depends where you live
2) audio is software encoded. connection on card
3) No
4) yes vcd, svcd - DVD requires 48Khz. currently Pv256 only does 44.1Khz -
People have been mentioning that the PV256 has problems
with AMD motherboards with onboard sound and video using
older VIA chipsets.
My motherboard has onboard sound which I have turned off
in the bios (using a SB Live). Are people having problems
with the PV256 when the onboard sound and video of the motherboard are turned on?
Do the problems clear up when the onboard sound/video are turned off?
Also, I read that the PV256 doesn't like to share interrupts. Is this true?
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 22nd Aug 2010, 00:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
New to DV, I have several questions.....
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 4th Dec 2007, 00:10 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 15:00
