Poll: Do you use other programs while burning DVDs
Be advised that this is a public poll: other users can see the choice(s) you selected.
Page 2 of 2
FirstFirst 1 2
Results 31 to 47 of 47
  1. Member 888888's Avatar
    Jan 2004
    Turdistan
    I am just about the most paranoid and obsessive person when it comes to multi-tasking while burning. I close all background programs such as virus scanners, firewalls, and mouse software. I also don't use a screensaver and I disable my internet connection. I even step away from my computer while burning. Yep, I'm nuts.
  2. Member Abbadon's Avatar
    Dec 2003
    Caribbean Sea
    Originally Posted by Cobra
    I have played UT2004 when burning a DVD before. It was accidental (forgot) but it worked just fine.
    Is that machine a dual Xeon with 1 gigabyte of ram ?
    If not, I will report you to the Computer Protection Facility nearest to your home for improper and abusive use of a computer.
    LOL !
    No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
  3. Originally Posted by Rookie64
    I have 3 computers - so I see no reason to multitask on the one that's burning 8)
    I also check that certain crap isn't running in the background and have screensavers disabled.
    I don't use an Internet connection at all on that computer, so I also don't have any virus protection or firewalls running.
    yep
    burn with my desktop(dedicated to dvds)
    do other things with my laptop
  4. Member zzyzzx's Avatar
    Baltimore, MD USA
    Did anyone else read the thread title and think it said Masturbating while Burning before reading the posts?
  5. YES ...
    Hence my post !!!
  6. Member RickTheRed's Avatar
    Aug 2004
    Up north
    Multitasking: never
    I shut down the computer before burning.
    Hey, some don't take chances.
  7. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Hmm, mental note: get Cobra addicted to Prestonias...
    Hey Cobra, you can OC a 2.4 Prestonia to 3.2 GHz and 1066 FSB pretty easily. The best part of it is: there's two of them
    FB-DIMM are the real cause of global warming
  8. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    I have 3 hooked to this KVM switch alone so I know the feeling
    To anybody worried about it or unsure, I suggest firing off a burn with a rewritable disc and have at it. Multitask everything imaginable and discover your machine's breaking point.
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  9. Originally Posted by sacajaweeda
    and be left with no machine.
  10. Banned
    Sep 2004
    Inner Circle of Thought
    It does not do any harm to multitask while burning.
  11. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    It's because they're scared we'll badmouth them. I pretty much do all the same things whether I'm burning or not. I may disable some services before I start to be on the safe side and I avoid the obvious things like virus scans and defragging. Everything else is fair game. :P
    Nothing can stop me now, 'cause I don't care anymore.
  12. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Cobra's already OC-ing his CPU so much it glows like a flashlight bulb
  13. I usually browse the web and have itunes going. And I have my Antivirus and firewall running in the background. Its usually not a problem.
  14. Member 888888's Avatar
    Jan 2004
    Turdistan
    Then when is it a problem?
  15. Banned
    Sep 2004
    When you are paranoid. :P
  16. Then when is it a problem?
    When I first got this computer I had some problems where dvds wouldn't burn all the way, they would get errors and stop at the same point... I have alot of coasters... I had a data dvd do that a little while ago too.
  17. I avoid using disk intensive programs like DVD authoring and imgtools while burning. Anything else is ok, even CCE. I burn with DVD Decrypter.
