How many of you multitask while burning DVDs?
What programs do you use while burning and what burning program do you use?
Results 1 to 30 of 47
The only other thing I do while burning is listen to music with WMP and browse the net.
Originally Posted by lordsmurf -
Oh, and I use Nero to burn.
Ever since BURP and burn-proof, it's near impossible to ruin a burn from overusing the HD or CPU. That wasn't true in the days of "if the buffer empties mid-burn, you're screwed", but all new burners have buffer underrun protection, and many have burn-proof which throttles back the burn speed to match the buffer replacement rate
I multi-task while burning all the time - running anything from Photoshop to Vegas, however I always burn off another drive (NOT my system drive).
I use Nero when I'm burning thousands of small files, but if it's just a couple hundred or less I use DiscJuggler. -
I'm afraid I've been ruined by the early days of CD burning on older systems where even if you moved the mouse the burn would crash and you'd have another coaster and if windows did a bit of minor auto-housekeeping the burn would fail.
I'm scarred for life so even on a 3ghz pentium I make sure that there is nothing else happening during a burn. -
I think todays burners have gotten much more reliable when it comes to multitasking as Cap mentioned with Burnproof capabilities
I never have anything else open when burning. Hundreds of burns I've never had a coaster.
I have played UT2004 when burning a DVD before. It was accidental (forgot) but it worked just fine.
I multitask all the time. I listen to music, surf the net, and play games while burning.
Hello,
I run an amd850mhz so I don't dare multitask even though my 4x microadvantage has a buffer (2mb I think
). I just feel safer letting it burn by itself....
Yes, no problems.
I also play Battlefield 1942 while burning with no problems.Originally Posted by Cobra
, no way! dang now you put idea's in my head Cobra
Glock scribbles furiously:Originally Posted by glockjs
"Gotta try burning a DVD while: 1) playing UT2004, 2)downloading Capmaster's prOn, 3) lurking at Videohelp and 4) port-scanning Naked Geek Networks' website"
I like to sit and watch the lights flash on the HD and the burner.
I have no problem waiting 15 minutes until a DVD burn is done. Of course I have my laptop to surf with when my main box is burning or encoding. Gotta have internet access.
I'm usually on the computer for a short time, so if I need to burn a disc, I'll do other things.
While I wait, I surf the 'net, listen to music, and sometimes encode. -
Nothing to heavy, and I usually make sure the apps I want to use are open before the burn starts.
Playing an MP3 while burning causes a reboot here.
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS -
I have 3 computers - so I see no reason to multitask on the one that's burning 8)
I also check that certain crap isn't running in the background and have screensavers disabled.
I don't use an Internet connection at all on that computer, so I also don't have any virus protection or firewalls running. -
Maybe it's your taste in music....Originally Posted by lordsmurf
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
Originally Posted by makntraks
very good
I don't do anything heavy - maybe do some printing or web surfing but no movies or music and certainly no gaming.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
Since my burner is 1x -- I usually have plenty of time on my hands and kill time by taking Rosie Palm out on a date.
Originally Posted by Ripper2860
There's always time for Rosey
I don't have any problems doing something else on either of my workstations while discs are burning, even to multiple burners :P
In fact I think I've realized why I got the latest computer: so I can play BF1942 while waiting for an encode/burn to finish
FB-DIMM are the real cause of global warming -
seems most everyone answered with yes in their replies, yet the poll shows it almost even....
so much for exit polling
Hello,Originally Posted by stiltman
Well glad you didn't announce an early result like the networks do!
Actually I'm sure it was people who didn't write a response
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Virtualdub "possible livelock" No multitasking. Newest version.
By zzyzx2 in forum Video ConversionReplies: 5Last Post: 6th Aug 2010, 05:08 -
Stability and multitasking in Linux
By Haopengyou in forum LinuxReplies: 13Last Post: 6th Nov 2009, 18:52 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
