i want to backup one of my dvd's and using dvd shrink ,i got this message copy protection error ,what did i wrong or forget or schould i use another programm,thx
Results 1 to 9 of 9
Hello,
That shouldn't happen
You can use iso read mode in dvd decrypter. This will copy the whole dvd to the harddrive.
Then open the iso file in dvd shrink. Then you can shrink it like normal.
That should do it
Hey gringos,
if i were you i would find a guide for dvdshrink and follow it
good guides to the left and here www.dvdshrink.info -
Once the folders have been created, go to nero, select dvd video. Drag your files from the right into the directory structure on the dvd on the left.Originally Posted by gringos
Click Burn -
Why burn with Nero, your choice though, when you can use DVD Decrypter to burn correctly
Have a look at my guide, I've made it as simple as possible with step-by-step instructions and screenshots and it avoids all that hassle with playing a DVD first, and you don't need to buy any software what I used is freeware
http://www.thescrapyard.pwp.blueyonder.co.uk/files/video/using%20freeware%20utilities%...r%20movies.htm
I swore Nero was the best at DVD-Video creation and ignore all those on here who said it was still buggy in that task, but found out the hard way ..... eventually
Great at burning CD's and data DVD's, but crap at burning DVD-Video's correctly
I personally found Nero was causing my problems with occasional pauses, even after a media change and using decent media, tried using DVD Decrypter instead of Nero to burn, my problems vanished. I proved it by burning onto the exact same media using Nero and DVD Decrypter, the disk burnt by Nero had problems the disk burny by DVD Decrypter had none -
Geez. I know I've been around this forum for awhile, not that I can start providing answers more often than I'm asking questions
Glad I was of help.
Rob
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
