Had a couple of dvd's that when finished burning in toast told me not all sectors were verified, please check dvd thoroughly.
Is this message a cause for alarm?
I can play dvd in dvd player and have selected a couple of different episodes and all seems fine.
Could it be I reading from an external firewire cd rom connected to my G4 and burning at a rate too fast for the dvd-108 to keep up? Or would it fail all together if it couldn't keep up with the burn?
Thanks again for all the valuable info!
Brian
Results 1 to 10 of 10
Just do a quick check of the DVD, if you have time play the whole thing. Usually it's a false alarm, some types of media will fail verification more than others. I used to get verification failures virtually every burn with Ritek G03s (but the discs always played perfectly in my DVD player).
I get verification errors when I sloppily handle a blank DVD and put a big ass finger print on the burning surface. The burn will complete but verification returns an error. The disc will play fine up until the fingerprint. grrrr
I use Ritek G04s and have never had a verification failure.
When I did have them, it was from Maxells and my drive was bad... (Though I still avoid the heck out of the Maxells) -
I have had a few bad sector reports during verification.
Highly unusual with Verbatim. With a couple of +RW discs I erased them and used again with no problem. Once had 25 out of 50 TDK-R fail verification and quite a few Fugi-R do the same. I use Taiyo Yuden-R now.Occasionally Verbatim +rDL. Question:are there any Toast 7 settings that are incompatible-Should verify data, simulation mode and buffer underrun prevention all be checked. What is the best combo or solo. could this affect bad sector reports?
Thanks. -
I've gotten the verification failure a few times. My test is to right click on the mounted DVD and select copy, then paste it into a partition. This will attempt to copy the DVD to the Hard Drive. If the Copy fails (usually blamed on a Disc error), then that means that if I ever wanted to duplicate the DVD it would also fail. I trash it and try again.
Slip of the tongue there Tugboat?
Some of the nosier folks on this forum might ask why not just duplicate the original - I however am not one of them
A Backup is a Backup. A Backup that can't be duplicated is not a Backup. No matter what kinda slimy things are crawlin' around inside yer head
Bad sectors when burning DVDs with Toast Titanium
By Akominatus in forum MacReplies: 3Last Post: 5th Apr 2011, 12:46 -
How to repair dvd with corrupt sectors AND bad video_ts.ifo?
By Spixe in forum Authoring (DVD)Replies: 8Last Post: 25th Jan 2010, 08:54 -
verifying sectors on a legit dvd
By Ryan in forum Newbie / General discussionsReplies: 3Last Post: 16th Jul 2009, 18:20 -
Bad Sectors on Rip from DVD
By AlfB in forum Video ConversionReplies: 6Last Post: 5th Jan 2009, 21:02 -
fixing bad sectors/Toast disk image
By danielmak in forum MacReplies: 6Last Post: 26th Jun 2008, 06:35
