  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Is it possible to run to instances of dvd2one at the same time?
    What We Do In Life, Echoes In Eternity....
  2. Banned
    May 2003
    Massachusetts
    Won't be quicker. The limiting factor is either the CPU, in which case running 2 at once will be slightly slower than 2 consecutively... or it's the hard drive, in which case running 2 at once will be MUCH slower than running them consecutively.
    So the answer is, basically, don't do that.
  3. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    ok
