I am thinking of sending a SHORT video sequence from my Canon camcorder. I guess it will have to be in Windows media format since the recipients are not very computer wise.
I want to make the actual physical size of the video "small"....no need for a full screen play. Can anyone suggest a good screen size for Windows Mediaplayer? I'm after a good quality but small picture.
OR would using TMPGEnc Plus 2.5 be a better option and encode to an .mpg file.
Thanks in advance for any help...
Hech54
Hello,
Well wmv would give you a smaller file size than mpeg (unless you did xvcd).
Try halfd1 at 352x480 or if it's not that great of a source use vcd resolution
Computer video?
320x240 MPEG1
160x120 MPEG1Want my help? Ask here! (not via PM!)
My son's grandparents will thank you two...
I never thought of VCD quality. I'm so hung up on mpeg2 recently I forgot how "cool looking" my old VCD's used to be. That should be plenty.....thank you guys.....my brain must have been elsewhere...
Help / 2nd opinion / advice needed from video experts - See attached Images
By sanchopanza in forum Video ConversionReplies: 5Last Post: 18th Mar 2011, 15:22 -
Video content for mobile devices: advice needed
By spycam in forum Newbie / General discussionsReplies: 7Last Post: 9th Nov 2010, 18:03 -
Help for video mailing
By Dalismann in forum Video Streaming DownloadingReplies: 2Last Post: 16th May 2010, 05:38 -
What's the efficeint way to store avi files for mailing ?
By AAC in forum Newbie / General discussionsReplies: 8Last Post: 16th Sep 2008, 17:37 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
