right here is the problem!! im on a 2mbit line so i get 240k/sec downloads yeahh,now after i installed dvd decrypter its slows down to 150k/sec,i know its not my net cos i have to reintall windows xp again then its fine..so i guess its this program!...i burn an .iso,then it just goes on a go slow!! any ideas![]()
1.pc has up2date anti-virus,spyware,etc (mcaffee)
2.windows fully updated
3.1 gig of ddr memory
4.amd 3200xp
5.2 nec dvd writes
hope u can help me guys!! thanksssss
Results 1 to 17 of 17
I highly doubt that DVD DECRYPTER is slowing down your internet. Try using trendmicro's free virus scan to scan your pc for viruses.Originally Posted by dj macca
http://www.trendmicro.com/en/home/us/enterprise.htm -
Originally Posted by handyguy
tryed that now!!goes up to 180/ksec now!! thats it ;-( -
try spotbot, you might have adware on your computer
member since 1843 -
you need to update your pc profile if you have an xp3200
certain apps drain all the pcs resources (eg widows movie maker) and mean that programs such as bit torrent struggle to work
you can often change the applications priority in order for it to not hog the cpu
do you only have problems when physically ripping the dvd or are you trying to say that merely having it installed on your pc is slowing your net down
usually virus scanning programs like norton and mcaffee are drains on systems resources also
avg is far less cpu intense
where are you getting the file that slows down from as unless its on a very fast server the problem could be with wherever you are getting the file from -
i have tryed all that!! its ok if i reformat u see!!!then its fasssssssstt!!
dammmmm -
Dvddecrypter has absolutely nothing to do with the net unless you tell it to look for an update every time you launch it.
im guessing you have cable internet? probably because your on a shared network, your speeds are going to change.....like the others said, dvddecrypter has nothing to do with your internet
I do remember of a report of DVD Decyrptor having a virus when downloaded from Bit Torrent.
Originally Posted by 888888
why would you download it from bit torrent???
www.dvddecrypter.com
They are lots of speed test sites, I'd try them or the ATI site give me 700 K/sec for the drivers
Here is a good speed testing site.
http://speedtest.cogeco.net/
mine broke the 5mbit barrier -
That's what puzzled me. Why would anybody sacrifice download speed and security just to use Bit Torrent for something that could be acquired legally and easily. But sure enough it was there in print on Zeropaid (I think).Originally Posted by glockjs
As he's UK based the speed tester at adslguide would be a better idea. I would also guess he's using adsl.
To the OP which isp are you using ?
Hardly think dvd dycrypter will slow his speeds down as i use it when my adsl is maxed out at 1 meg and it has no effect at all and my system is no where near as fast as his.....
Only thing that could maybe do it is if they are both reading/writing to the same h/d and the drive is running slow... Long shot at best.
Not bothered by small problems...
Spend a night alone with a mosquito -
You don't think it could be your isp, could it? Otherwise I would guess its a background process running that is eating up your internet connection. You could use the program Windows Startup Inspector from www.spychecker.com to determine what programs are not necessary to start up at boot. If that doesn't work and you think its your isp, talk to me about live-cds.
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 15:48 -
dvd decrypter
By dr strange in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2009, 15:11 -
DVD Decrypter from one pc to another
By jwedge in forum ComputerReplies: 3Last Post: 27th Jan 2008, 00:35 -
I am using DVD Decrypter
By Lissettep in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Oct 2007, 17:55 -
Help with DVD Decrypter
By Me-Hostage in forum DVD RippingReplies: 10Last Post: 20th Aug 2007, 09:12
