I downloaded a mpeg file. Burned it to a cd using nero. then viewed it on the computer. All was fine. But when I played it in my dvd player the movie was black and white. It was colored on the computer. Does anyone have any suggestions?
Look at the dvd compatibility list on this site to see if it will play on your dvd player.
click on SEARCH here at the top and typ black and white and select the hardware playing forum.
My dvd player is listed. I have downloaded several movies that were just fine. Since it was a mpeg file I just burned it to a cd.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
