I get a lot of movies that are in PAL SVCD format. I usually just convert them to NTSC DVD, but doing this really balloons up the size of the file. I'd like to be able to make it so I can shrink the size back down so I could fit more than one movie on a DVD. I was thinking that instead of changing it to DVD I could just change it to NTSC SVCD, but I was wondering if that would affect the quality any? Does reencoding it to a different SVCD format make it look worse than changing it to DVD? I was also thinking I could still keep it in DVD resolution, but change the bitrate to SVCD's, that way the file size would still be low. Is this a better idea? Thanks for any responses.
Hello,
Why not encode to a lower dvd bitrate???? That way it would still be dvd but use up less space
Use a bitrate calculator to determine the rate for the amount of time you want:
https://www.videohelp.com/tools?s=1#1
You could also use halfd1 resolution 352x480
Yeah, that's what I figured would be the best thing to do. Thanks for the reply.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
