From DVD Faq (http://www.dvddemystified.com/dvdfaq.html):
----A disc also can have up to 32 subpicture streams that overlay the video for subtitles, captions for the hard of hearing, captions for children, karaoke, menus, simple animation, etc. These are full-screen, run-length-encoded bitmaps with two bits per pixel, giving four color values and four transparency values. For each group of subpictures, four colors are selected from a palette of 16 (from the YCbCr gamut), and four contrast values are selected out of 16 levels from transparent to opaque. Since one of the four values is usually 100% transparency (to let the video show through), only three combinations of colors and transparencies are left, making overlay graphics rather crude. Subpicture display command sequences can be used to create effects such as scroll, move, color/highlight, and fade. The maximum subpicture data rate is 3.36 Mbps, with a maximum size per frame of 53220 bytes.
I need an authoring program that can do subtitle effects (fade in/out in particular) for PC.
The only I know that can do that is Apple DVD Studio Pro 3 [http://www.apple.com/dvdstudiopro/specs.html] but is only for MAC.
Anyone knows a dvd authoring/tool that can do that?Subtitling
* Subtitler integrated into application
* Add up to 32 subtitle streams per track
* Set position, font, size, style and color, fade in and fade out
* Enter timecode or drag in Timeline to set start, stop and duration
* Built-in title safe and action safe areas
* Use graphics in subtitles
* Import subtitles in .son, .stl, .txt, and .scr formats
* Use buttons over video
Also would be great if the program can handle subtitle overlaps.
Results 1 to 1 of 1
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 12:45 -
TMPGEnc Authoring Works - highlighted area fade in/out problem
By daniel66 in forum Authoring (DVD)Replies: 3Last Post: 16th Mar 2010, 14:50 -
which dvd-authoring program is better?
By siluet in forum Authoring (DVD)Replies: 9Last Post: 8th Oct 2008, 14:25 -
Fade subtitles in VirtualDubMod
By shorto in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2007, 21:01 -
Fade-in\Fade-out filter, VirtualDub MOD
By GangstaRap in forum Video ConversionReplies: 3Last Post: 21st May 2007, 20:58
