Hi, one and all,
Captured a clip from my dv by WinDv, then I use Tmpg compress it to DVD, try to open with Vdub, got a error message " no video frames found in mpeg file" but the files play back ok by real player or windows media player. Do u know what's the reason for this?
Also, when play the .avi file captured by WinDV, it seems VDub is in a slow mode. Like you pressed "slow play'' button on a VCR, but I have a 320x240 .avi file played in normal speed in Vdub![]()
What happed there![]()
Do I need to setup something in VDub?
Newbie is looking for help.
You will need to either get the MPEG2 plugin for the standard VirtualDub, or use VirtualDubMpeg2 or use VirtualDubMod to be able to open MPEG2 files.
For playback, it depends on the attributes of the AVI and the power of your PC. If when playing back, the output screen (the right side) is playing then the video is passing through the Vdub video processing system as if it was rendering so it will need lots of system resources and will slow down, especially if it is a high-resolution, low resolution will probably keep-up and not slow down.
Have a look at your CPU usage while the AVI is playing back in Vdub, it's probably sitting on 100% and still needs more.
VDub - Audio From Another Source - Speed Issue
By hech54 in forum EditingReplies: 5Last Post: 10th Dec 2010, 12:28 -
DVD Play Back
By rcoran in forum Portable VideoReplies: 1Last Post: 4th Oct 2009, 03:26 -
play back problems
By heyhi in forum DVD RippingReplies: 4Last Post: 10th Mar 2009, 12:12 -
upside down play back
By suomiaussie in forum Software PlayingReplies: 2Last Post: 14th May 2008, 14:22 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 21:03
