Does anyone know what this error means? i keep getting it trying to install a pc game:
Windows/system32/autoexec.nt
the system file is not suitable for running ms-dos and microsoft windows spplications.
anyhelp would be great. thanks guys.
Sounds like it's telling you that it thinks you are trying to install a MS DOS game on a NT based system (XP). Probably an error, unless it is indeed a MS DOS game. I would go to the games site and see if they have installation advice.
yes, i thinks it is a ms-dos game. its LSL: love for sail...but i can't figure out how to install on XP... any advice. The game site is not much help.
In general MS-DOS programs will not run on XP, but: Here's a link to a site that discusses your problem. http://www.the-underdogs.org/guidewin.php
I found it by doing a Google search for 'ms-dos games on XP'. There are other sites with info, also. First thing is to try 'compatibility mode' and set for W95 or W98. (Right click on the file and select properties. You should see a listing for compatibility.) You can try this, might work. -
A friend of mine had a similar problem recently trying to install a cheap racing game for his children on an XP system.
The solution was to find the REPAIR folder in the Windows directory and copy the autoexec.nt file and the config.nt file to the SYSTEM32 folder, thus overwriting the versions in the SYSTEM32 folder.
This error seems to happen when the autoexec gets corrupted some way.
He tried it and the game installed and ran fine afer that. -
Well, i replaced those 2 files, and i got it to get past the one error, but now on the initial load screen, i get an alert message:
Alert: Error opening resource 10000.snd
Use ENTER to retry
ESC to quit
Any idea what this is, and what i have to do to get past this?? Thanks. -
Further info on the error message:
Error 99: Error loading resource 10000.snd
l:\sys\interps\restype.cpp(97)
Script# 64989 ($fed6eeb8+)
Thanks.
has any one had trouble installing roxio easy vhs to dvd 3
By dirtfarmer in forum Capturing and VCRReplies: 0Last Post: 30th Apr 2012, 23:04 -
Trouble Installing to OS X 10.5 (mencoder, mplayer, mpeg2enc.intel)
By gabroll in forum ffmpegX general discussionReplies: 21Last Post: 10th Nov 2010, 10:48 -
MAC users PLEASE help!! Having trouble installing ffmpegX on OS X 10.4
By lvtovc in forum ffmpegX general discussionReplies: 1Last Post: 9th Dec 2007, 09:19 -
Problem installing Mac game
By The Monkees in forum MacReplies: 8Last Post: 12th Nov 2007, 08:04 -
Help! having trouble installing anydvd, clonecd and clonddvd
By Ade007 in forum Newbie / General discussionsReplies: 1Last Post: 15th Jul 2007, 17:41
