I just got a home made DVD from England and it rolls ( vertical will not hold) on my tv. When I play it on my cpmputer with Power DVD it works fine. It is not a ripped DVD but an unprofessional home movie. Could it be PAL and not NTSC and if so why does Power DVD play it and how can I convert it to NTSC. I tried a straight rip and burn with DVD Decrypter but it makes no difference.
Doug
Results 1 to 10 of 10
It is probably PAL format.
A computer monitor is capable of PAL and NTSC but USA model televisions can only handle NTSC.
If you want to watch it on a regular TV then you either have to convert it to NTSC and burn a new NTSC DVD-R ... or ... you can buy a DVD player that plays PAL and converts to NTSC on the fly.
A popular inexpensive choice there is the Philips DVP 642 which many retail stores sell for $69.99 + sales tax or use PRICEBRABBER.COM and order it on-line for as little as $62.99 with free shipping (I just checked).
The benefit of having the Philips DVP 642 is that is can easily be "hacked" to be made region free and with it's excellent built-in PAL to NTSC conversion you will be able to play any DVD from anywhere in the world.
There is probably an easier way but I know this will work:
Rip the DVD to your HDD using FILE MODE in DVD Decrypter.
Open up one of the VOB files in VirtualDubMod.
In VirutalDubMod go to FILE then FILE INFORMATION and it will tell you the FPS and frame size.
NTSC is 29.970fps 720x480 and PAL is 25fps 720x576
Actually they can be various different resolutions since it is "home made" but PAL is always 25fps with a hieght of eiher 576 or 288 whereas NTSC could have a height of either 480 or 244.
704x576 25.000fps
I guess that answers my question.
Now the best way to convert? I am looking for quality not speed. -
It ain't easy my friend!Originally Posted by dcook
You will need AviSynth plus the SmoothDeinterlacer for AviSynth plus a MPEG-2 encoder such as CINEMA CRAFT ENCODER.
Also if the audio is MP2 I would change it to AC-3 so you might need BeSweet or some other AC-3 converter.
Then you will need a DVD Authoring program like TMPGEnc DVD Author.
If you feel up to doing it read this here post:
https://www.videohelp.com/forum/viewtopic.php?t=219852
I'm not gonna hold your hand but if you run into a specific problem then I might be able to help.
- John "FucliLvies" Coleman"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Holy crap!!!!!!!
I am unclear whether or not it will keep the simple menu but I will attempt it anyways.
Thanks and wish me luck. -
No you cannot keep the menu. When you are done you will have to re-author and create your own menu as well as re-creating chapters etc.Originally Posted by dcook
Rolling Shutter and Deshaking
By blewyn in forum EditingReplies: 8Last Post: 5th Feb 2012, 16:45 -
VHS with interlaced AND rolling FIELDS?
By Heiler in forum RestorationReplies: 22Last Post: 22nd Oct 2011, 18:08 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 05:52 -
rolling/jumping with VHSc
By highaim in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2009, 22:03 -
Tools for Rolling Credits
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 28th Apr 2008, 16:53
