I really want to buy a DVD player that supports DivX/Xvid files.
Unfortunately, the one I have my eye on does not support subtitles (is there any DVD player that does yet?).
So I wonder:
* Is there an application (or an easy and fast method) that can combine a DivX/Xvid clip with a .sub/.srt subtitle file into one .avi file?
You must reencode the video if you want permanent subtitles. You can use virtualdub and the vobsub filter, https://www.videohelp.com/srtsubsvirtual.htm . Instead of frameserving you save as a new divx.
DivX dvd players with switchable subtitle supports:
https://www.videohelp.com/dvdplayers.php?DVDname=&Submit=Search&Search=Search&divxsubs=...y=Name&hits=25 (be sure to read the commmmments)
How to position a subtitle in a .srt file ?
By momo1984 in forum SubtitleReplies: 24Last Post: 24th Feb 2019, 04:01 -
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56 -
Can't input a subtitle file (SRT) to Xvid4PSP
By mahogany in forum SubtitleReplies: 3Last Post: 26th Mar 2010, 07:01 -
[Question] How to insert an SRT (Subtitle) file into an AVI file?
By Greg14 in forum SubtitleReplies: 5Last Post: 30th May 2009, 04:54 -
how to convert an .idx subtitle to a .srt file??
By vinayak1986 in forum SubtitleReplies: 1Last Post: 9th Sep 2007, 11:53
