I'm sure it isn't that hard to create a slipstreamed disc, or to download the network install version <which is the method I used>
But what about that not so computer saavy guy that doesn't understand all that, and visits Windows update to install SP2? Then it borks his entire system.
I can understand both sides of the story here. PRO SP2 - do some homework, and find creative ways to install the update. CON SP2 - All I should have to do is update, and it should work no questions asked.
I think it should work no matter what. The average user should not have to find out if every piece of hardware has up to date drivers, and this and that, just to fix security holes in an operating system.
I believe MS was a little hasty in releasing this to the masses so soon. But it was a double edged sword. They needed something, and something fast.
Myself, I don't give a damn if it works or not. I've been using Windows since the 3.1 days, and am use to updates not working, and am suprised when everything works like it should. This is the case with most software, not just Microsoft. I only have XP on 2 machines. It worked fine on one, but not the other, neither had a sucessfull install over a current install with SP1. Did I dig for the problem? No, because I just don't care enough to spend that much time on it. For my important computer tasks, I've always used Linux (which of course has many flaws of it's own).
Results 31 to 32 of 32
I'm not some Microsoft fanboy, but you do hav to look at it realisticly.
must read stories, 11-17-09
By deadrats in forum Off topicReplies: 1Last Post: 17th Nov 2009, 22:13 -
Graphics card for some Videoediting
By Dash1 in forum ComputerReplies: 11Last Post: 10th Jun 2009, 15:29 -
New Horror Movie
By hauntedtony in forum Off topicReplies: 0Last Post: 22nd Aug 2008, 18:09 -
HDD setup for videoediting too ?
By Dash1 in forum Capturing and VCRReplies: 8Last Post: 11th Dec 2007, 10:11 -
DivX playback problems on Philips DVP 3040 (since installing WinXP SP2)
By mikester2 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 22nd Nov 2007, 12:54
