Hello everyone this is my first post so please forgive any terminology I mess up.
I've searched for someone expereincing a similar problem as me, but was unable to turn anything up...
Basically, I have a Sony MircoMV camcorder. I hate the sony software and I get good results bringing my video in (quality wise) thru an s video connection to my aver media tv card. However, at one point in my home movie (sisters graduation) between the ceremony and reception the tape "hiccups" (meaning it pixilates and pauses for a second).
For some reason, TMPG i think believes this is the end of the tape even though there is about 4 minutes more and cuts it off. If I run the video through canpus pro coder to basically reencode the file, no matter what I try (VBR 2 pass, 8000 max bit rate) the quality suffers. However the video from canopus can be burned on a dvd using tpmgenc and dvdwriter.
So in essence, I want to know if there's some way to tell tpmgenc to stop looking for the end of a video on its own and just encode (or since its in mpeg 2 already from teh tv card, just "transcribe") the file into audio/video ts folders without cutting anything off. Lastly, it cuts off at 1.85 GB. Is there a setting somewhere perhaps that denies files bigger than this in tpmgenc? I know my windows settings are okay (NTFS file system and the original file caputred is 2.45 GB).
Thanks!!
use source range and encode the first part and then use source range and encode after the bad spot and do the second part ..
dont know why procoder would give you bad results though --- it does very good job .... why you buy it ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
also - this is posted in the wrong section ....
I purchased it to convert my microMV movies before I bought the capture card with the hardware mpg2 encoder. I dont know why I cant get good results...its always my luck though!Originally Posted by BJ_M
For my target i use DVDNTSC and i change from CBR 6000 to VBR2 8000
any ideas on how to create better output? (motion thats not so choppy..) -
check the field order
Help! Cannot rip this DVD - wierd problem...
By Comfy in forum DVD RippingReplies: 2Last Post: 8th Dec 2009, 11:10 -
WIERD DVD data disk problem
By bruinflight in forum Newbie / General discussionsReplies: 24Last Post: 25th Sep 2009, 00:53 -
More wierd Vista behavior...
By ahhaa in forum ComputerReplies: 2Last Post: 28th Jun 2008, 21:05 -
Wierd REWIND Problem... on standalones only!)
By taboo in forum DVD RippingReplies: 4Last Post: 16th Feb 2008, 22:29 -
Help! Wierd problem of Sharp Aquos 46D64U
By cryogenics in forum DVB / IPTVReplies: 3Last Post: 3rd Dec 2007, 23:56
