Can i increase the audio of an avi file?
You could separate the audio and video tracks. If the audio track is AIFF or PCM you can use a sound editing application such as Sound Studio to normalize the audio (adjust it volume). Then put the audio track back with the video.
Pretty sure in QT pro you can hit Apple-J select the sound track and adjust the volume.Originally Posted by MacdanKeeper of the "Unofficial" iMovie FAQ also for the lastest iMovie news click here
Your source for iMovie answers and what not! ;-) -
However once you do, then exit the file, QuickTime will ask you to save the file. Doing so will wrap your DivX inside a MOV container. Most people dont want that to happen.
Was under the assumtion the only thing that changed was the extention that you could easily change back to AVI. No?Originally Posted by AntnyMDKeeper of the "Unofficial" iMovie FAQ also for the lastest iMovie news click here
I found it in quicktime but i can only once edit the volume and save.
I need it to do many more times because the audio signal is verry week.
Any sugestions? -
Someone suggested that in another thread but I havent yet tested it myself.Originally Posted by DanSlagle
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29
