I'm authoring for the first time with DVD Lab and I'm having a couple of problems. First, should I be able to hear audio in my movie preview window? I'm not hearing anything, but the frameserved file I imported does have audio. Second, I somehow have hidden my assets window. My preview window now covers the entire bottom third of my screen from right to left. I don't know how I did it, but I'd like the screen to look like the opening screen from DVD Lab. If I try to start over, DVD Lab gives me the same look, not the original windows. Thanks.
I've never heard audio in the preview.
The windows moving around on their own is a problem DVD-Lab has had for quite some time. You can click-drag the windows. Move the 2nd third (assets) down to the bottom and then move the preview window to the right side. Should look like the default setup.
Can anyone confirm if the Pro version(s) has this window problem addressed? -
to reset the windows click the view menu and select reset bars + windows (Pro version here)
I also have never heard audio in the preview. -
The preview window does not have audio when viewing video. In some installations (depending on what codecs you have set up) you can drop the audio stream on the preview window and hear audio. You cannot have both at the same time though.
I sometimes have the windows shift on me. I have never found a satisfactory solution, and all it takes (for me, anyway) is to drag them back into place on the occassional times it happens.Read my blog here.
DVD-Lab Pro: DVD-R DL burning problems
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 07:57 -
DVD Lab Pro Audio Problems
By Outcast212 in forum Newbie / General discussionsReplies: 6Last Post: 21st Feb 2009, 02:11 -
DVD Lab Pro - Using VOBs, Audio Problems
By teacozie in forum Authoring (DVD)Replies: 5Last Post: 24th Sep 2008, 01:12 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 07:52
