Hi
Could somebody explain something to me, I recently bought a nec 3500 and I used the nero burnspeed thing to see what speed my burner was burning at, and after the test it came back saying that the max that it had burnt at was 2x and the line on the graph was quite flat, I was using datalife 8x dvd - r and I thought this burner was supposed to burn at 16x, why isn't mine then, could be my set up:
1.1ghz Duron
64mb Ram
30gb harddrive
windows me
Or could it be something else?
Thanks in Advance
If you used the Nero "burnspeed thing" and chose any other option than "Create Data Disc", this did not show how fast your DVD burned, but how fast the DVD you burned was read back,commonly referred to as "ripping". Stock firmware on this drive has a rip-lock on it to keep it lower.
How long did it take to burn the disc ? That will give you a better idea of what speed it was actually burning.
Also, you can go over to www.cdfreaks.com and look in the NEC section to find more info on your drive.
Tom -
You can use hacked firmware to burn faster, but it will void the warranty.Originally Posted by lockett1977
NEC ND-4550A Problem
By drakster in forum DVD & Blu-ray RecordersReplies: 3Last Post: 3rd Jul 2010, 13:25 -
Install Problem with SVCD2DVD 2.5.3500
By ebbtide123 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Nov 2007, 12:46 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 22:07 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 14:13 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:05
