hello,, i want to know is ripping to DiVx have better quality then SVCD or not?? if yes,, which program is best for this job.. TIA
Results 1 to 12 of 12
Hello,
It CAN be. It depends on how high of a bitrate you use. You'll have to decide that.
Virtualdub is a good choice
If its a typical movie a 2 disc xvid will be far better quality than a 2 disc SVCD......PERIOD, plus you aint encoding borders (or hacking the poor movie to pieces to fill the screen area).
Originally Posted by monzie
Originally Posted by qt4eva
Virtualdub is a good program for editing DivX AVI files, not for encoding DVD IFO and VOB files. I'm sure that Virtualdub doesn't recognise VOB or IFO files. You can however, create a script file of the video and WAV audio in order to encode with Virtualdub.
You can download other programs aswell that convert straight from DVD IFO and VOB to a DivX AVI file. Thats if you would prefer to do it that way. -
Originally Posted by soneman
I wouldn't open them directly though. I'd use AVISynth scripts and DVD2AVI to frameserve into it (only if you want to get your hands dirty). Or just use AutoGK, Dr Divx or SimpleDivX if you want a no-brainer.If in doubt, Google it. -
I personally would recommend FairUse Wizard for either XVID or DIVX. It is very easy to use and can be set to full or semi automatic and with or without advanced settings. I primarily encode to DIVX for compatibility with my stand alone players. However, the program has XVID "built-in" because it was considered superior to DIVX (uses your external DIVX codec). Either way, the program saves files into projects and requires alot of free hard disk space. Encoding can take 2 to 4 hours with 2 passes on 2+ hour movies. I've been able to get seven 2+ hour movies onto 1 DVD with pretty good (enough for me) quality. The same movies are all under the 700MB limit I set in the program, averaging 590MB each.
I have not used the programs mentioned above so I can not comment on them or compare them to FairUse Wizard. -
you should try AOA DVD Ripper,it can copy your favorite DVD movies to AVI (DivX, Xvid), VCD (MPEG-1) and SVCD (MPEG-2) formats. You can download it from this link:http://www.dvdxcopy-software.com/aoa-dvd-ripper/ -
You might do a comparision between DivX video at a given bitrate and resolution, and mpeg2 encoded video at the same bitrate and resolution - and DivX (or "any" mpeg4 codec for that matter) would win.
/Mats
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
