I've got an older Hauppauge WinTV PCI card (with FM) that I put into my new-ish Athlon 2600 (on an Asus A7V8X). I have a DVD burner and Pinnacle Studio 9, so I'm hoping to be able to capture video (either from cable/broadcast or from old VHS tapes). I also have a copy of PowerVCR II from Cyberlink.
But here's the problem, or should I say "problems": (And yes, I have done quite a bit of searching to find similar problems/solutions here, but no luck.)
* I can capture from within Pinnacle (after upgrading to 9.3.5), and edit within there (nuke commercials etc.), but I can't schedule recordings, and it often freezes my computer;
* I can capture within WinTV2000 and get AVI's that Pinnacle Studio will open and edit, but again, I can't schedule recordings. (Doesn't freeze the computer, though.)
* I can capture with PowerVCR II, which schedules recording beautifully in a number of flavours of MPEG, but Pinnacle won't open any of the files it captures. The error message Pinnacle gives is "The video file <filename> could not be opened. Studio does not support this progressive scan (non-interlaced) MPEG2 video file format.";
* I can capture with the WinTV Scheduler that Hauppauge has for download at www.hauppauge.com, but it also makes MPG's that Studio won't open. And for those, it just says "could not be opened," with no explanatory second sentence.
I need a solution which will let me capture on schedule with the Hauppauge WinTV PCI card, in a format that Pinnacle Studio 9.3.5 will be happy to edit. Surely someone out there has done this.
I'd prefer not to have to buy any more software, in the hope that what I've got already will do the job with the right tweaks. Freeware's fine, shareware preferably if it's dirt cheap.
I also have a need to convert WMV captures (from web streams) into something that Pinnacle Studio 9.3.5 can edit; I've seen a few different shareware things, but they don't work, and I don't know if it's because of the particular WMV's or the software itself. What's a good cheap (or free?) solution there?
Thanks!
Robnorth
I do not have Studio9. But I have used WinTV/Schedule to capture
using PicVideo and 640x480. Then, I used Studio 8 to edit and burn
the captured file. -
WinTV Scheduler captures using WinTV2000 so you should get the identical file format as capturing with WinTV2000.
At least I think. -
That's one weird thing. WinTV2000 in itself makes .AVI files, but Scheduler makes .MPG files. I haven't found any 'Options' link in Scheduler that gives you a way to change that.[/quote]WinTV Scheduler captures using WinTV2000 so you should get the identical file format as capturing with WinTV2000.
At least I think. -
PicVideo is a very good video codec. The trail version will put a watermark
on the bottom of the screen. You can also get rid of the watermark by
paying them ~$30 for a paid version. You can find it from TOOL section
of this web site. You can also read others comments about it.
After you installed PicVideo, you open WinTV2000 and select PicVideo
as video compression method there. Also configure the PicVideo using
quality arround 19. Then, you are done. Try the trail version first to see
if it works for you or not.
Good luck.
Capture with Hauppauge WinTV PVR.500 VHS
By Asesinato in forum Capturing and VCRReplies: 2Last Post: 31st Mar 2012, 11:33 -
How can I convert and edit Hauppauge WinTV .ts files to make a DVD?
By mgreen10 in forum Video ConversionReplies: 14Last Post: 6th Nov 2011, 22:52 -
Questions about Hauppauge 1196 WinTV HVR-1250 PCI Express Card
By Wizard23 in forum Capturing and VCRReplies: 15Last Post: 25th Feb 2011, 16:22 -
Will Pinnacle Studio9+ work with Windows 7???
By rrtbusa in forum Capturing and VCRReplies: 0Last Post: 14th Dec 2009, 19:06 -
Pinnacle PCTV HD or Hauppauge WinTV-HVR-950?
By dannywho in forum Capturing and VCRReplies: 0Last Post: 30th Apr 2008, 12:29
