My recorder is displaying U99. Does not matter what I do I can't get the tray to open or the recorder to do anything. The manual says to turn it off and back on however have tried that numerous times. I have even tried unplugging it but nothing helps.
Any ideas?
Enjoy your new paper weight
Would you care to expand on that? What exactly does it mean?Originally Posted by FulciLives
Pushing the power button on the unit for 10 seconds is supposed to reset it on my Panasonic.
That code from a Panasonic usually means it is done as in broken, not working, worthless other than maybe as a paperweight.Originally Posted by jackedup
Running 3 displays on 560Ti?
By mr-scarface in forum ComputerReplies: 0Last Post: 20th Oct 2011, 02:56 -
Multiple displays
By alintatoc in forum ComputerReplies: 2Last Post: 18th Dec 2010, 17:53 -
Subtitle displays problems
By dudeman316 in forum SubtitleReplies: 12Last Post: 6th Nov 2009, 11:17 -
Dual displays: how to display same on both?
By Quimbly in forum ComputerReplies: 10Last Post: 22nd May 2008, 21:48 -
Split TV for 2 Displays... (help!)
By zephirus79 in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2007, 22:46
