  1. Circuit City has both on sale for 100 bucks...
    Lite-on SOHW1633s
    Sony DrU710A
    Any idea which one is better? Or should I spend my money on something else? If so, what?
    thanks and peace,
    jay
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    I'd get the Pioneer DVR-108 (OEM version) or the DVR-A08 (retail version)
    - John "FulciLives" Coleman
  3. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    pioneer dvr 108 is around $80 at www.newegg.com that includes shipping when i checked the other day. thats what im about to get
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Lite-on SOHW1633s
    Sony DrU710A
    thanks and peace,
    jay
    both of those drive are made by LITEON. SONY dvd burners are rebadged LITEON's. As John mentioned get a Pioneer 108. the oem 108 can have bitsetting automatically by flashing the drive with the PIODATA firmware.
    check out this thread from the Pioneer forum at cdfreaks.com
    http://club.cdfreaks.com/showthread.php?t=113369
  5. Member Skith's Avatar
    Bottom of the ocean
    You should read the http://www.cdfreaks.com review of the BenQ 1620. Also check out the forums on the above site. This drive is fast, supports error scanning, overspeeding of many media, and good quality. Personally, if I had known about this drive, I would have got it (BenQ) instead of the NEC3500A.
    Good Luck!
    Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
  6. Neither one. I'd suggest either the NEC 3500 or the newest Benq model. Both of my NECs put my Benq 822 to shame when it comes to burning DVD-R media, but my Benq is SLIGHTLY better at DVD+R it seems... The Benq will be able to do PI/PO tests as well, but if you're planning on burning -R media I think I'd still suggest NEC. My Benq will not even recognize several of my -R media codes, and a couple others burned on it were pathetic in comparison to my NEC -R burns. It's great with +Rs though...
  7. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    I have a Sony DRU710A and it has been good so far.
  8. NEC 3500 discs play in everything.
