  1. It's been asked before but I need your advice. Buying a PC to capture both VHS and Mini. Will the type of video card make much of a difference? My intent is to use the PC to create DVDs as a hobby and maybe a business down the road. Here are my choices...
    128MB PCI Express™ x16 (DVI/VGA/TV-out) ATI Radeon™ X300 SE
    128MB PCI Express™ x16 (DVI/VGA/TV-out) ATI Radeon™ X800 SE
    256MB PCI Express™ x16 Nvidia® GeForce 6800 GTO Graphics Card
    What do I do and why? A newbie thanks you in advance.
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    The video card is only used when you display something on your monitor, or for the TV output. It does nothing for the capture other than display the results. I'd say get a decent one but don't other with a higher end one unless you plan on doing some gaming.
  3. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    or you plan on rendering 3-D animations with programs such as cool 3-d
  4. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    You should be more worried about what type of capture card/device you will be buying than what video card you will be buying.
    Of course there is that "special case" ... ATI
    ATI makes a line of video cards that can also capture. Usually they are called AIW (All In Wonder) or VIVO (Video In Video Out).
    - John "FulciLives" Coleman
