Need HELP!
I ripped a DVD using flexion's DVD to VCD guide. Used smartripper - ok. Converted wav to mp2 using toolame - ok? Then converted d2v to avi using VFAPICodec which I tried to open in Virtual Dub. VDub can't recognize file.
I have dvd2avi.vfp in the same folder as dvd2avi.exe. What am I doing wrong?
Thanks in advance for your help.
Yup, I already did install VFAPICodec, ran vifpset.bat and converted d2v to avi. Still, VDub can't determine file type of resulting avi.
More help, please! -
we'll i was not going to answer because i don't have your problem solved but the same thing that is happening to you happened to me. I am not sure exactly what i did to get mine working but i know i kept messing with it and i was able to finaly get virtualdub to open it. I know i reinstalled virtualdub to another directory and made sure i installed the handler and then rebooted the computer. I think i also installed vfapi again. I just recently reformatted my hard drive and again ran into the problem you are having so i reinstalled everything again changing there directory and not putting the files in a folder, just leaving them in my directory. Don't ask me why this did the job. all i know is it started working and that is all that matters. YOu could try defragmenting your harddrive or running a utility like norton. this sometimes fixes the registry and or harddrives. I know this might not help you but give it a try and sooner hopefully then later it will magically appear like mine did. Hope this gets you started to finding the problem.
Computer wonīt recognize DVD disk
By dexter30 in forum MediaReplies: 10Last Post: 4th Sep 2010, 14:52 -
PC won't recognize burned files to DVD
By browndav in forum MediaReplies: 6Last Post: 9th Jan 2010, 15:43 -
Burner Won't Recognize Blank DVD-R Discs
By ddowden1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 23rd Aug 2009, 06:52 -
Sonic won't recognize DVD, computer does ...
By LittleQueenie in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2007, 13:06 -
DVD drives won't recognize any discs
By TIBGustaf in forum DVD & Blu-ray WritersReplies: 10Last Post: 3rd Jul 2007, 07:29
