I have a Pioneer DVD player in my 04 Z71 Suburban. I have tried Sony DVD-r, Radius DVD +R, Taiyo Yuden Silver Thermal +R, and Memorex -R, in attempting to find the HOLY GRAIL of dvd discs that will work.
For all of the discs, I changed the bitset to DVD-ROM prior to burning with DvdDecrypter. I have been ripping with DVD Shrink 3.2.
The Memorex discs will always start playing, but freezes after about 5 minutes.
The Radius will sometimes work.
All the others either just sit there and spin and come up with nothing, or the word "FORMAT ERROR" appears on the screen.
Pioneer says that player is made by someone else especially for GM...therefore it appears to be a propriatary player that has no model # and Pioneer isnt claiming.
I am going broke trying to find the right discs to burn so the kids can watch some flicks in the truck. Any insight or suggestions (other than taking a freakin hammer to the player) would really be appreciated.
thanks and peace,
jay
I use Prodiscs myself. I had a few complaints about discs I burned on my previous burner, an LG, having playback problems. I haven't had any problems since switching to NEC. I don't suppose you have a different burner you could try?
ok...
I have a Micro Advantage 8x...
If I had a choice between these two, which one would be preferable...
Sony16x or
Lite-On 16x
thanks -
Have to ask someone else on that one, I am fairly new to this myself. Pioneer and NEC are the best from everything I've seen. After owning products by both companies, I think the quality of NEC stuff is better.
You said you tried Taiyo Yuden DVD+R but you probably will have better luck with the Taiyo Yuden DVD-R discs.
I have a Pioneer DVD player that is GREAT model but it is an early model DVD player and as such it very picky with when playing back CD-R and DVD-R media.
Has no problems with Taiyo Yuden CD-R and Taiyo Yuden DVD-R
It also likes the CD-R and DVD-R media that MAXELL makes (but only the MADE IN JAPAN branded MAXELL media).
Looking For A Remote For A Pioneer Laser Disc Player
By DJboutit in forum Newbie / General discussionsReplies: 0Last Post: 11th Dec 2010, 17:43 -
Will A DVD Data Disc Work On Mac As Well As PC?
By blazin-j in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2010, 10:52 -
Disc of Xvid files work on DVD Player but not PC
By MattG in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2009, 06:43 -
DVD copying with Nero - demands DVD/RW disc and still doesn't work.
By gorelle in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2008, 05:44 -
Disc will/wont work between different DVD players.
By Scroogle in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2008, 15:41
