Hi, I wantet to make a collection dvd out of some of my anime episodes..
Anyway, when I try to import the avi files (file) i only get this message:
So, how do I fix this? Any reasoanble possibility to fix this so I can burn it to dvd and play it..Could not import file Naruto - 01 TW.avi.
Video files for this project must have a resolution of 720x576 or 704x576.![]()
Results 1 to 12 of 12
CrAp!
What is the resolution of the file? and what format is the audio in: PCM, MP3, MP2, or AC3?
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
640x480 (1.33:1) [=4:3]
audio:
0x0055(MP3) ID'd as MPEG-1 Layer 3
128 kb/s (64/ch, stereo) CBRCrAp!
Yep, that's a problem with Encore. It will only accept video in what is sees as the proper reolution.
You'll need to convert your clips to either of those resolutions. When I've got video in other resolutions I've been using TMPGEnc to transcode it to MPEG2 before inporting it into Encore.
It's worked for me. -
Ok, il'l try that! But, can I "mass convert" files? I mean, I have like 109 episodes! :P
So, It'l take some time to convert those...CrAp!
Two choices...
1) Let your computer do some major crunching over the next few days..
2) Capture directly into MPEG....
The second choice is better..
Drop Encore, and go for something simpler..Not necessary.. -
That will work, and no, Encore is not to andvance so I still want to use that..
Anyway.. When i Try to make divx -> mpeg with tmpeg shouldent I rip the sound by itself? Think I read that someplace! And then I would have to do it manually on all episodes!CrAp!
Procoder has a batch function, just drag and drop all 109 eps in, and will convert them for you.
Procoder express has a "WATCH FOLDER". Create an empty folder, move all of your avi's over, and Procoder Express will convert everything in that folder to your desired target.
You could create avs's for each ep. AVISynthesizer would make this easy. Supports right-click extenstions, and custom teplates. Drag and drop all avs files into CCE (SP or Basic) and it too will encode all to desired target.
Those 3 options are a little easier than creating batch encodes with TMPG and/or Mainconcept's MPEG encoder. Though, both of those have short cuts to add to batch, ctrl-alt-m for TMPG, and Insert for MPEG Encoder.
Other options are an authoring app that will re-encode for you. But you mentioned you are happy with encore, so no need to mention this.
How do you use Adobe Encore CS3?
By Banleno007 in forum Authoring (DVD)Replies: 2Last Post: 20th Feb 2012, 12:33 -
Adobe Encore
By mobie29 in forum Authoring (Blu-ray)Replies: 33Last Post: 6th Jan 2011, 02:09 -
Adobe Encore question...
By sdsumike619 in forum Authoring (DVD)Replies: 18Last Post: 5th Aug 2009, 01:58 -
Adobe Encore Help
By Entengdigital in forum Authoring (DVD)Replies: 0Last Post: 17th Jan 2008, 03:36 -
adobe encore question
By meshnut in forum Authoring (DVD)Replies: 5Last Post: 5th Dec 2007, 16:53
