Hi folks,
I'm relativley new to the complexities of ffmpegX, but I have had some success converting a couple of DVDs to fit on a 256Mb card for my Palm.
To cut a long story short - my HD died on the iBook, and I've just got round to installing ffmpegX 0.0.9p on the new drive to discover it doesn't work as before.
Simply put, when I use the MPEG4 (mencoder) codec at any scale other than 720x576 (ie when I reduce the framesize for the Palm screen) it just goes ping and generates an empty AVI. If I just load my VOB file and hit encode without changing any parameters it works fine.
Closer examination of the terminal outputs show that the scaling routine appears to be trying to use AltiVec... I'm on a G3 so that won't work...
Is that my problem? The mencoder codec now requires a G4? Can I download an earlier version of ffmpegX (& mencoder) that'll run on my G3?
Thanks in advance
Steve
I don't think the G3 should be a problem. Try to post your complete process output to major4@mac.com
MTS unable to play in WMP11/unable to edit in Movie Maker
By xxx4reggie in forum Newbie / General discussionsReplies: 6Last Post: 23rd Nov 2011, 00:04 -
How do I scale up a video?
By Dapuma in forum Newbie / General discussionsReplies: 5Last Post: 19th Apr 2010, 08:58 -
Unable to burn DVD, unable to access the Video_TS.ifo.
By Asymmetry in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2008, 00:02 -
What is a scale factor?
By rocky12 in forum Newbie / General discussionsReplies: 47Last Post: 22nd Jul 2008, 15:34 -
How to add watermark to a video with mencoder or how to scale with FFmpeg?
By ApplePro in forum Video ConversionReplies: 16Last Post: 21st Nov 2007, 10:12
