Hi,
I bought a DVP642 recently, and I have the questions"
1. The AVI from Digital Camera won't play, do you know what is the problem?
2. Does it support Unicode text subtitle files? It seems not
3. It does not support idx/sub subtitle, I cannot get it working.
4. How can I get the the Chinese external subtitle working when I plays AVI files. It displays funny character during playback.
1) There are certain requirements for DivX files. AVI is a container and may not necessarily use DivX. For example, you can have AVI files that use other compression codecs, such as Indio, and they won't work at all. DivX files can't use Quarter Pixel and there's something else they can't use, but I don't remember. The user's manual talks about it.
2) it does NOT support Unicode!
3) SRT subtitles work. I'm not a big DivX user and I have not been able to test sub/idx subtitles. I can only say that SRT does work. Some have reported that sub/idx doesn't work, but Philips claims it does.
4) You can't fix this. Subtitles must either use Latin letters or Cyrillic. Chinese is not currently supported. The users manual describes what format the subtitles must be in. Cyrillic must be in ISO-8859-5 format, which is an old format nobody really uses any more.
Only .idx subtitle supplied
By saymell in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2010, 00:17 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
Does any of these players support sub titles .srt/.idx/.sub?
By torrentkid in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Mar 2009, 10:16 -
about idx subtitle
By sg999 in forum SubtitleReplies: 4Last Post: 5th Nov 2008, 02:25 -
Player with SUB/IDX subtitle support?
By Chatable in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2007, 11:43
