    May 2004
    Chicago South Suburbs
    Have had two different copies of From Justin To Kelly from same source. DVD Shrink encounters "Cyclic redunancy" errors, and, if I try DVD Decyrpter first, it encounters read errors in one file.
    Is there something about this movie that defies "back up"?
    Checked shrink with different disc of a another movie, anayized fine, so I don't think shrink or decyrpter are corrupted.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    There are plenty of other rippers out there, smartripper for one. Here's a list of others to try:
    https://www.videohelp.com/tools?s=7#7
    Good luck
    Kevin
  3. It is more than likely the actual disc (spot on the disc).
    2 things to try:
    1. play the dvd on your pc player using wmp or intervideo, etc. THEN, try to rip it
    2. Rip what you can in file mode to your hard drive. THEN let the drive cool down and try to rip just the vob file that is giving you problems
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    the disc could be dirty with smudges or something. you could try using a older version of DVD SHRINK like version 3.05. you can find it at this link:
    http://www.mrbass.org/dvdshrink/dvdshrinkold/
