Hi, i here with a "novice" question again..![]()
sorry ya
I have this 2 avi file, which i manged to merge them into one using virtualDub taught by fellow expert here.
SO e next thing i did was to convert the avi into DVD output.
I tried usingWinavi , e result a file more than 4.9Gb..
( took around 50min)
Thus me went to try tmpgenc XP...but which was veri slow. *in e process now* ( I est time will be 3-4hrs at least)
May I ask why e conversion time of 2 diff program is such a big diff ?
Will the est file size shown at TMpgenc reliable ? i really don wish to wait for such a long conversion time end up File size is more than wat a DVD disc can handle...
Pls advise![]()
Hello,
Well you could use a bitrate calculator:
https://www.videohelp.com/tools?s=1#1
That might let you get closer to your target - and try to have the value a little less than the projected number to ensure you'll have it fit.
ALSO:
Author it anyway and use dvdshrink to make it fit. You'll lose a little quality but you wouldn't have to reencode it at least
Because they are two different programs, written by two different people (teams?) using differnt tools, different designs and with differnt aims.Originally Posted by devilxb
If your source is good enough quality, you will see that TmpGenc will almost certainly produce a better looking mpeg than winavi. Thats where some of the extra processing time goes!
avi audio help/confusion??
By turbopwr in forum AudioReplies: 5Last Post: 2nd Mar 2010, 17:30 -
Aspect ratio confusion with .avi on standalone.
By Nocontact in forum Newbie / General discussionsReplies: 60Last Post: 15th Jan 2010, 13:54 -
Bluray confusion
By Border Reiver in forum Newbie / General discussionsReplies: 6Last Post: 5th Nov 2009, 16:41 -
Interlace confusion
By Bagshot in forum Capturing and VCRReplies: 7Last Post: 16th Feb 2008, 08:46 -
16:9 to 4:3 confusion
By zabolots in forum Video ConversionReplies: 5Last Post: 17th Jul 2007, 14:32
