I have WinTV-GO card. I tried to capture video using VirtDub. I can only capture with 352x240 resolution max. Is there any capture drivers that is compatible with WinTV-Go card and allow me to capture video a least 480x480? Please help.... any info. is appreciated.
I never used one before, but if the card is BT848/878 based try the universal WDM driver http://sourceforge.net/projects/btwincap
As you will see, itīs still under development and may cause some minor problems depending on HW configuration.
In my case, it works fine. -
What OS do you use? I use the same card under Windows ME and capture with VirtualDub at 352x576 (VfW Drivers). No Problems. Remember that you have to switch off overlay display at this resolution.
Since you did not list your system specs, I'm assuming your machine has enough horsepower to capture with minimal frame dropping at resolutions higher than 352x240.
Start up VirtualDub and go to File/Capture AVI.
Under Video, turn on Preview mode.
Under Capture, click on "Hide on capture".
Now you can go in and set a custom size such as 480x480.
You won't be able to see what you're capturing, but you should be able to get a rough idea of when to start/stop via listening.
Overlay mode for many graphics cards is limited to ###x240/288. Trying to change the 240/288 to a higher number will give you an error message in Overlay mode.
<font size=-1>[ This Message was edited by: TheInformer on 2001-11-29 08:45:28 ]</font> -
TheInformer, thanks for the information I had the exact same problem and it worked.
morharsar, Also make sure that virtual memory is correct(don't let windows do it for you). I used both Huffyuv and PicVideo compression.
videocast osprey capture resolution
By jaybird in forum Capturing and VCRReplies: 0Last Post: 27th Apr 2009, 23:29 -
Force custom resolution for TV out in CLONE mode for DV Capture ?
By TheParadoX in forum Capturing and VCRReplies: 4Last Post: 6th Oct 2008, 20:00 -
tv tuner/analog capture resolution problem
By cooldude859 in forum Capturing and VCRReplies: 4Last Post: 13th Dec 2007, 02:16 -
Capture Hi8 using what resolution?
By chrishallowell in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2007, 12:57 -
capture resolution
By stompinne in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2007, 15:45
