  1. http://www.adstech.com/products/USBAV702/intro/usb702intro.asp?pid=USBAV702
    can someone tell me what kind of capture device this is so i can find the right guide for capturing from it. thx!
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    It records directly to mpeg:
    Originally Posted by adstech
    Capture from any analog video source in MPEG-1 or MPEG-2 video formats including
    VCD, SVCD and DVD formats
    Capture DVD (MPEG-2) at video bit rates from 1 Mb/sec. up to 15 Mb/sec.
    Use the “Direct to Disk” feature in DVD Movie Factory to capture and burn to disk
    in one simple step.
    Any dvd authoring software will automatically recognize this format
    Kevin
  3. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    It's a cheap (low quality) capture device made by ADS. It's their second-generation USB capture box. The first one, the USB Instant DVD was a sync nightmare because it used the PC sound card for audio capture.
    The second gen. box of theirs has improved the sync, but now the video quality is abysmal. ADS never really got a handle on making these things right. I would avoid them. There are many good quality cards and boxes out there made by Canopus, Hauppauge (WinTV), etc. And inexpensive. No need to go with poorly designed stuff like ADS anymore.
    Do a forum search here and you'll likely see a few screen grabs from truly awful captures the Instant DVD produces
    Comments are the author's opinion alone, and your mileage may vary
    And ..I'm moving this to the Capturing forum ...hold on to something .....
