Hi
I have got a file that I would like to burn onto dvd, I have clicked on it and it says its a bin file and there is also a cue file as well, but in the actual name of the file it mentions kvcd, could somebody please tell how I would go about doing this so it would work on a stand alone dvd player?
Thanks in Advance
Take "any" CD writer (Hell, even Nero does this without f*cking up!
) load the cue, hit burn. In Nero, just cancel every "wizard" that pops up, then open the cue under the file menu, Open. A KVCD is a non standard VCD, so should be written to CD-R/RW.
If it will play depends on your DVD player, if it plays VCD at all, and out of specs VCD in particular.
/Mats -
No, with Nero (maybe it varies with version?) Select "Burn Image" on the "Recorder" menu. Select the CUE file. Then burn to a CD.Originally Posted by mats.hogberg
Actually, both ways are available (at least on my version 6.3.0.2)
/Mats -
You're right. Sorry! If you use File -> Open you may have to use the file type pulldown to select 'Image files..." to see ISO, BIN/QUE etc.Originally Posted by mats.hogberg
No prob - I'm so used to going the File menu way, I hadn't noticed there was another (and simpler) way of doing it.
/Mats
