i've been working with the toolkit for a few days now and have created some VCDs with menus etc., but when i use the still shot w/audio as a menu screen, the audio is very very choppy. is this falling below the minimum bitrate that the standalone player will handle? i'm trying this on a pioneer 343, and it has no problems with still-only menus, the a/v play sequences, or anything else i'm doing, just when i use an audio-only stream, whether in a menu or play sequence as an event.
if anyone else has found a way to get this to work on (preferably pioneer) standalones or knows that it can't work, i'd appreciate the help.
patrickm,
Check out this link. It has some recommendations for what you are doing.
http://www.icdia.org/cdprosupport/vcd/vcd2x/vcd_audio.htm
BTW, I haven't tried what you are doing, but I have a Pioneer changer. The specs should be the same though.
RF -
thanks for the response, but i've actually seen that before, and what i'm doing seems to be legal- still JPG and muxed audio file. but it seems to make real fast jumps in the audio, almost as if it is reading the still between every 1/4 second audio segment or something. any ideas about any type of fix that would involve pauses or something? i thought MPEG stills with audio were supposed to be part of the standard, and that was pretty black-and-white. i could just make a still video, but that's pretty wasteful, since a JPG is 50k and a 4 minute video is 40Mb...
Have you tried it without the still, just the audio? Maybe there's a problem with the audio file.
RF
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
"Toolkit" for using a laptop to play video and audio onto a tv
By bobogs in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2011, 21:49 -
Phillips DVP5982 vs Phillips DVP5992?
By jarko in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th Jul 2008, 13:41 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 14:16 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 11:07
