Results 1 to 17 of 17
  1. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Hi
    I have a Lite-On SOHW-8125, DvdinfoPro, Kprobe 2.4.2.
    Whenever i use DVD Decrypter to change the book setting to DVD-ROM on a dvd+r and then write the image with DVD Decrypter afterwards DvdinfoPro still shows the dvd+r as "Book Type DVD+R" when i use Kprobe, which does not have a burning feature that i know of, i have to burn it back with nero but it still shows under DvdinfoPro as dvd+r.
    What do you need to use to change the book type to show or be dvd-rom ?
    canada
    Go to cdfreaks.com,they have a liteon booktype setting app plus they have dvdrw omnipatcher that will patch your firmware so its set to dvd-rom bitsetting automatically.
    Jan 2004
    PAL Region
    Try using the Lite-On BitSetting utility.
    It may or may not work for your model:
    This tool only used for LITEON drives (specific models only). Not all
    of the LITEON DVD ReWritable drives support this BookType utility.
  4. Banned
    Jun 2004
    Okay, i'll give those a shot.
    When i use DVD Decrypter and recheck or "query" it says it is changed but after i burn it DvdinfoPro say's it's not ? i figured if DVD Decrypter & Kprobe was saying it was changed it would be & my model was capable of being changed ?
    Thought i read somewhere that Stomp record now max would burn it back without changing the book type because nero set's it back to dvd+r when burned ?
    I also see the Lite On bit setting utility has a Burn Now button ?
    And when i choose to change it, it says it was changed successfully & to use nero or whatever ??
  5. Banned
    Jun 2004
    Hey
    Okay, Cool!!!!
    I used the Lite-On BitSetting utility, burned back with Nero and it now shows the DVD+R as "Book Type DVD-ROM"
    YEA!!!!!!!
    Anyone know if it's possible to change the book type on a "Plextor PX-708A" ??
    Thanks Again!!!!!!!
    Jan 2004
    PAL Region
    Read me.
    From the CDFreaks.com Plextor Frequently Asked Questions thread:
    Q Do the Plextor DVD recorders support bitsetting? What is bitsetting anyway?
    A Yes the new Plextor DVD recorder support bitsetting, although the PX-504A does not. The Plextor PX-708A/UF drives support bitsetting when firmware 1.08 (or higher) is installed, the PX-712A/UF/SA drives need firmware 1.05 (or higher) installed. The bitsetting option can be enabled via the Nero software (v6.3.1.25 or higher), DVDInfo Pro software (v3.29), or PlexTools (v2.17 or higher). It's preferred to enable the bitsetting option via the PlexTool software because once you enable bitsetting via PlexTools it will always be used, meaning that you don't have to enable it every time or have PlexTools running in the background. Of course, you can disable or enable bitsetting at any time using PlexTools, meaning that it's not permanent.
    P.S. You might want to try a quick search on the web first... 'Plextor PX-708A bitsetting' gave those above results on the top of the stack.
  7. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Heh.. Should really try'n do a search for this kinda stuff first.. :P
    Hey
    Okay, Cool!!!!
    YEA!!!!!!!
    Thanks Again!!!!!!!
    Seth
    :star: :star: :star: :star:
    Archived DVD Scans
    Nero V ImgTools V Decrypter
  8. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Thanks Again!!!!!!!
    you need to edit your registry first before installing PLEXTOOLS and use the latest version of NERO BURN 6.6 or 6.3.1.25 and use Plextor 708 firmware 1.08. USA bought drives did not have PLEXTOOLS included until the 712A drive was released.
    1. open up notepad then copy and paste the following down below, name the file plex.reg
    __________________________________________________ ___________
    REGEDIT4
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Juxtaposition]
    @="11111111"
    "Parameter"="11111111"
    __________________________________________________ ____________
    2. then save the file like in my documents.
    3. right click on that plex.reg file that you saved in my documents, then click on merge, it will install the plex.reg file into your windows registry.
    4. install plextools, reboot pc
    5. open up plextools, click on the 708A drive, click on drive settings, click on advanced make sure there is a check mark in the CHANGE BOOKTYPE FOR DVD+R.
    The key to installing this is you have to do the windows registry edit first then install plextools. good luck!
    Btw to the Mods: I hope I haven't broken any forum rules by posting the instructions. If I have let me know.
  9. Banned
    Jun 2004
    Hey
    Okay, Cool!!!!
    YEA!!!!!!!
    Thanks Again!!!!!!!
    Seth
    :P
    Yeah... i found it about 2 minutes later, about the plextor... it was for a friends. 8)
  10. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Ahh...LoL. Sorry, I've been dying to use that..heh heh.
    The new version of CD-DVD Speed has booktype settings, by the way.
    Seth
    Archived DVD Scans
  11. Banned
    Jun 2004
    Thanks Again!!!!!!!
    REGEDIT4
    @="11111111"
    Thanks budz
    Already made the .reg file and gonna e-mail it to my friend, he is downloading the stuff from plextor now.
  12. Banned
    Jun 2004
    Seth
    LOL!!!!!!!! yeah, i was talking to my friend on the phone when i saw it and was telling him about the bart punishment!! LOL!!!!!!
  13. Banned
    Jun 2004
    Thanks Again!!!!!!!
    Do you know if version 6.0.0.0 of nero will work for the plextor ??
    Or will he have to download the newest one ?
    I have 6.3.1.25 installed & v6.6.0.1 Ultra Edition downloaded but not instlled yet.
  14. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    NERO 6.0.0.0 will not work in order to enable BITSETTING for the 708A drive. NERO 6.3.1.25 OR 6.6 will enable BITSETTING for the 708A drive.
  15. Banned
    Jun 2004
    Okay, just wanted to make sure. He burned a dvd+r with clone dvd and it came out as a dvd-rom for book type but he is also downloading the newest nero to try.
    Thanks Much!!!!!!!!!!
  16. Banned
    Jun 2004
    Thanks for the link!!!!!!!!! the proggy worked great and i got the newest firmware to flash my burner also!!!!!!!!!!!!!!
  17. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Your welx!
