To obtain a proper diagnostic you need, before analysis, set up the configuration file: MPEGReference.ini
The values of all parameters follow the ISO 31818 spec. For example:
Frame rate = 29.97 is represented by:
'FrameRate=4'
An aspect ratio of 16/9 by:
'AspectRatio=3'
and so on.
If you don't change MPEGReference.ini will obtain as resutl: Failed! every time.
Regards,
Gabriel
PS: This version of MPEG Validator only support MPEG legacy media, ie, audio AC-3 give us: NO AUDIO
Results 1 to 1 of 1
How to Be Sure It Will Be Possible to Revert to Previous OS Boot?
By jeanpave in forum ComputerReplies: 4Last Post: 1st Nov 2011, 18:41 -
Automatic jump to the next VTS from the previous
By src2206 in forum Authoring (DVD)Replies: 4Last Post: 28th Sep 2011, 05:32 -
VLC: opening at previous size?
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2011, 01:45 -
Previous Versions of tsMuxeR
By DirectorSG in forum MacReplies: 2Last Post: 18th Sep 2010, 05:44 -
Previous Button not working with Playlist
By chickspirit in forum Authoring (DVD)Replies: 0Last Post: 27th Feb 2008, 15:39
