I noticed a few DiVX video files I downloaded were a bit jumpy. However most are not. Is there a way to correct this ?
I usually convert the DiVX files to DVD Mpeg2 compliant files via Tmpgenc and then author to a DVD with TmpencAuthor and Nero.
These files are jumpy as DiVX files and also (of course) jumpy when converted to Mpeg2.
The 'jumpiness' probably comes from corruption in the file. You can usually scan for bad frames and cut them out with Virtualdub. There are a few DIVX repair programs that can occasionally help also. (In 'Tools' <<<)
Some downloaded DIVX files are encoded by real idiots with old software and no idea of what they are doing. You can clean them up, but it takes a bit of work. -
I'm using DiVX 5...
However playing the file in VirtualDub it did not jump as it did in the DiVX player, Winamp or Windows media player. So I was able to resolve the issue by frameserving the DiVX file to Tmpgenc 2.51. As I wanted to convert the files to DVD....
Now the file plays fine on all my DVD stand alone players... -
this also happens if the interlace field order is read wrong in the header.. you can fix this with a 4c changer found in the tools section
The reason for this is VirtualDub uses the actual REAL codec to decode the video unlike WMP (bag o' shite) or WinAmp which use Direct Show 'FILTERS'. Forget those 'media players' and try something like VLC/ Videolan, MPC or Zoomplayer (and install FFDshow if you haven't already) for playing video files...in fact get them all....and DONT EVER EVER POST EVER AGAIN SAYING YOU USE WMP....EVER.Originally Posted by kenmo
Forum is 'Jumpy'
By olyteddy in forum FeedbackReplies: 6Last Post: 18th Nov 2010, 23:09 -
Avi to dvd jumpy..?
By Mozzy31 in forum Authoring (DVD)Replies: 7Last Post: 7th Feb 2010, 05:05 -
wmv to avi (divx/xvid) conversion jumpy output file
By famine99 in forum Video ConversionReplies: 5Last Post: 14th Oct 2007, 12:09 -
By famine99 in forum Video ConversionReplies: 0Last Post: 11th Oct 2007, 22:04 -
Jumpy DVD ?
By Dash1 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2007, 15:53
