i am using x-copy platnum and when i play my burned DVD's in my panasonic pv-d4743s dvd/vcr combo, they skip and play very slowly.
what am i doing wrong???
cheap crap media,is most likely the problem
might be the burning speed,or software,but the problem mostly lies with cheap unreliable media,even ritek,etc are prone to batches that are mediocre at best.
it may even be the format that there on,+ or -. some players just dont like certain formats either. -
the problem is xcopy software which is crappy to begin with. use DVD SHRINK & DVD DECRYPTER to back up your dvd movies. use good quality DVD-R media. Panasonic DVD players can only playback DVD-R MEDIA. Unless your pc dvd burner is capable of BITSETTING to DVD-ROM then DVD+R media can be played back on PANASONIC dvd players.i am using x-copy platnum and when i play my burned DVD's in my panasonic pv-d4743s dvd/vcr combo, they skip and play very slowly.
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
recommend dvd player skips fbi warning
By joshua4 in forum Software PlayingReplies: 5Last Post: 24th Jun 2010, 02:43 -
DVD player skips certain parts in a burned DVD
By dzsoul in forum Authoring (DVD)Replies: 18Last Post: 29th Oct 2008, 19:19 -
DVD Doesnt Play Correctly On Stand-alone Player! (Skips)
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 16Last Post: 12th Sep 2008, 20:07 -
Burned DVD skips in standalone player
By lj01 in forum Newbie / General discussionsReplies: 14Last Post: 21st May 2008, 11:07
