I used svcd2dvdmpg for a few days and decided I really liked the program. So I sent my donation and downloaded v1.5. When I tried to install it I got the oxc registration error. So I went through the forums and found the fix. I edited my boot.ini. I also went to system/properties/advanced/performance and turned off DEP.
Added the file "msiexec.exe" from windows/system32 to the list.
And finally I went to microsoft looking for answers. None of these solutions worked for me. I am at a loss as to how I'm going to get this program installed. Any help would be greatly appreciated.
Hi firedx11,
If you think it's a Windows poblem rather than the software, check out http://computercops.biz - it's mainly a PC protection site but they do cover general PC stuff too.
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Can you post a screenshot of your error messages?
Sure thing. Here it is. I believe it to be a DEP error. But for some reason I have no way to work around it.
What does your boot.ini look like now?
This is a copy paste of my boot.ini
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(1)partition(1)\WINNT
[operating systems]
multi(0)disk(0)rdisk(1)partition(1)\WINNT="Microso ft Windows XP Professional" /fastdetect /execute -
can you do uppercase as in:
/EXECUTE
& give that a try?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I tried everything. So I went ahead and did a clean install of my operating system. Downloaded my updates. And I finally got the program installed. Thanks for you help though.
Registration Problem
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 2nd Feb 2012, 00:14 -
Got trouble with MSINET.OCX on Windows 7 (64-bit)
By paytonlow in forum AudioReplies: 1Last Post: 14th Oct 2010, 01:18 -
registration problem SVCD2DVD
By stgreene in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 8th Nov 2009, 01:32 -
By pauloggie in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 30th Jun 2008, 05:56 -
By wazzabee in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 12th Apr 2008, 16:50
