I see that SurCode is selling this for only $99, and it claims to produce a 6-channel DTS surround .wav file (44.1khz) for use in burning audio cd's. The DVD version does the exact same thing, but at 48khz also, and costs $499.
My question is this: if the output of the program is a standard .wav file, couldn't you simply re-sample it to 48khz? Or would that kill the DTS encoding?
More importantly-- why not simply create a non-standard DVD with 44.1khz audio?
This certainly seems to be a cheap way to create digital surround sound...but somehow also seems too good to be true...
the output is not a standard wav file , its a digital file with a wav header ..... if you play it on a system that doesnt do dts decoding , you will hear some nasty sh*t ....
no -- not pink noise... it has a square wave component - its digital noise , not random like band pass filtered pink noise ..
a simple idea to use the dtswav for your projects
you need:
AVI file
DTSWAV
AVImuxGUI/VirtualDubMod
a DIVX compatible player (-> ~ EUR 70)
simply mux your AVI with this DTSWAV but beware of the over all steam, some player canīt be feed with streams (video + audio) over 2000kbs
I did some testings with the KISS 450 - no problem at all even above 2000kbs
bye Daphy
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 17:25 -
SurCode DVD PRO command line
By hd1 in forum AudioReplies: 0Last Post: 14th Feb 2011, 06:00 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 13:10 -
Surcode or alternative
By prizi in forum EditingReplies: 2Last Post: 8th Dec 2008, 11:23 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 08:06
