Is there a way to transfer files between two computers using Firewire WITHOUT having to set up a network?
Are there any softwares that allow this?
Both computers are running Win XP Pro.
Hi waheed,
What type of files? Just any files in general?
Maybe, if you could configure it and your PCs, any FTP software might work...? There's loads out there...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Here is a start......Originally Posted by waheed
http://www.homenethelp.com/web/explain/about-firewire-networks.asp
Search is your friend.....
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
I'm just curious why you wouldn't want to set it up as 1394 networking as that is the simplest method. Is there a conflict with other network devices?
FB-DIMM are the real cause of global warming -
No, im just curious to know if it were possible to transfer files without setting up a network. It is possible for USB, just wanted to know for Firewire.
Thanks for the replies.
I already have a network set up (using a router to connect to internet), just didn't want to alter existing settings. -
You should be able to piggyback the 1394 onto your existing network. I used FireWire to transfer files between my two workstations since it was faster than the ethernet cabling, you just bridge the two networks. Nice thing is you don't even have to mess with a crossover.
If you already have both computers networked via a router(w/ inbuilt switch I'm assuming?), then you just need to enable sharing the drive with the source files (right-click on the drive in My Computer or Windows Explorer, and go to sharing and security). You should then be able to access it from the destination computer just by going to Start Menu > Run and typing \\sourcecomputername\sharename.Originally Posted by waheed
If I have assumed wrong, then
If in doubt, Google it.
Questions about DV transfer and connectivity of Firewire/1394
By Movie-Maker in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 13:46 -
Transfer AVI files from Laptop to Desktop via firewire?
By manhnt in forum Newbie / General discussionsReplies: 11Last Post: 1st Aug 2008, 14:51 -
Firewire transfer from Sony HDR-HC1E
By Richard_G in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 26th Apr 2008, 22:21 -
Bland picture after firewire transfer?
By Jazzy78910 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 31st Dec 2007, 06:10 -
Frame drop in firewire HDV transfer
By Dinu Bandyopadhyay in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 19th Oct 2007, 11:29
