I have a .avi video file and since it doesn't play in quicktime (standard) i recon it's encoded in xvid at a high resolution (hdtv)
I'm planning on importing those file into idvd, but i encounter a few problems here:
since idvd doesn't support xvid i have to decode/encode it into a file that is supported
would that be .mov only or does idvd also support .mpg or divx?
What program can i use to decode the xvid file?
i hope you can help me out
greets
benny
it's a .avi
Divx 960x528
23,976 fps
1973kbps (240,8kbyte/s)
audiocodec: framecopy (format=2000 chans= 6 rate: 48000 bits)
since i'll be making the menu's in idvd i'll try to encode the file into a mpeg4 .mov tonight
i hope it'll work
Decoding LG HB966TZ
By mikestar in forum Blu-ray RippingReplies: 2Last Post: 20th Oct 2011, 04:19 -
subtitles gone after decoding
By Meredy in forum SubtitleReplies: 1Last Post: 7th Jul 2009, 07:52 -
Cuda decoding
By b33rman in forum Blu-ray RippingReplies: 4Last Post: 28th Feb 2009, 08:46 -
Xvid4PSP and DD decoding
By CineManno in forum Newbie / General discussionsReplies: 8Last Post: 25th Jan 2009, 11:55 -
decoding whit XVID or FFDshow
By technoplume in forum Newbie / General discussionsReplies: 0Last Post: 22nd Sep 2008, 14:24
