I have a project saved in Adobe Premiere Pro and want to import it into Mainconcept Mpeg encoder. I have the regular encoder, not the plug-in for Adobe. The project is a sequence of about 8 separate videoclips. Do I have to import each AVI file separately, or is there a way to import the whole project as I file?
you could frame serve it out of premiere -- or use the premiere encoder as it is the same thing ..
I'm new to all this so please bear with me. When you say I can frameserve it what do you mean, and can I do this in MC encoder, and how would I do it in Premiere Pro? Thanks
install the debubugmode frameserver for premeire and frame serve it to your external encoder ... some guides are over to the left
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 03:08 -
MainConcept MPEG Pro HD Question
By Nuke Shower in forum Video ConversionReplies: 3Last Post: 27th May 2008, 22:48 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 20:27 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 15:56
