Hello,
And I would like to know which program works decently... if you have you VHS player connected to your computer and you want to Capture ALL of the video on one file and then be able to use an authoring program and burn it. Thanks a bunch!
P.S I currently am using the ATI player and it will just stop at random points and not record...>_> if anyone knows the answer to that, it would be great.
That sounds like MV kicking in. Get a MV defeating device. The ATI MMC software should work fine for capturing after that. Visit Lord Smurf's site (www.digitalfaq.com) for info on how to best use MMC.Originally Posted by Phrosty
Anyone knows why i don't have option "tv" in my mmc ?
Dealing with the same, installed software yesterday (9.1), but can't continue, cause i cant follow lordsmurf advices, do i have wrong version ?
M -
You may want to start your own thread for that problem. It would not be fair for you to start asking questions about a different problem in someone else's thread.Originally Posted by wijdbeens
Originally Posted by lordsmurf -
Virtual VCR works great. Simple to use. I use HUFFYUV codec (lossless) with great results. JUST MAKE SURE that you close all programs running in background, otherwise you will have dropped frames. You can get all these progs free on this site (see "tools")
Good luck
Phrosty:
There are software macrovision "hacks" available for the ATI MMC. You can see a reference to them here(including download links):
http://www.digitalfaq.com/capture/atiavi/atiavi.htm
I suggest you try them first to see if they work, before you invest in a hardware solution. When I had my ATI AIW 7500 the software hacks did work on my system. -
...I spent 1 hr and 21 mins waiting for my movie to finish captureing ( I followed this http://www.digitalfaq.com/capture/atiavi/atiavi.htm) and when it was done I went to go see if my file was there and it wasnt! I even did a search still nothing came up. I've done it before with just the regual way of doing it and it just kept on stopping the capture at around 26 mins. Thanks so much for helping me and if I ever get this solved " me love you guys long time."
Capturing VHS to computer and then watching on tv from dvd
By the_bear99 in forum EditingReplies: 2Last Post: 25th Sep 2010, 11:29 -
Capturing from Toshiba W808 S-VHS VCR into computer
By HDClown in forum Capturing and VCRReplies: 1Last Post: 1st Jan 2010, 15:33 -
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 13:06 -
Qaulity Capture Card for VHS-DVD & Computer TV Viewing/Capturing
By RubicksCube13 in forum Capturing and VCRReplies: 1Last Post: 11th Nov 2007, 09:00 -
Capturing Halo 3 gameplay from computer monitor to computer
By Jamo in forum Capturing and VCRReplies: 1Last Post: 13th Oct 2007, 01:06
