  1. Hi, just wondering, if I burn VCD on a CD-RW disc with Nero or Easy CD Creator, do I still start follow the Create VCD choices in the program? Also once a VCD is burn, is the CD reusable? or Nero/Easy CD will close the CD and can't burn any more?
    Samson
  2. Yep your CDRW's are still reusable.
  3. I have not been able to reuse my CDRW's What is the process of making them reuseable?
  4. Both Nero and EasyCD have a CD-RW eraser. You need to do that before you can reuse it.
    I've used CD-RWs for VCDs and played them on a couple of DVD players. They worked the same as a VCD burned on a CDR. YMMV.
    Blaine
