Hi!
I'm intending to transfer all my concert VHS tapes to DVD.
I'm going to borrow a DVD-recorder. I have several options.
I don't have any doubts that the picture quality will be well-preserved once transfered to DVD. However, I have some doubts when it comes to sound. Many of my tapes are recorded in mono sound. By recording to DVD-R it will be automatically converted to "stereo". Does anyone have any experience with this and what do you think about sound quality? Will it simply remain the same (just mono sound put on two channels) or will it become a bit hissy ?
Thanks in advance!
It will be 2 channel mono audio.
It should sound about the same it sounds now but it ain't gonna sound any better.
If you will be using a mono VCR you will need a Y adapter to convert the single mono out to "stereo" in on the stand alone DVD recorder.
I will be using stereo VCR, cause I have few stereo VHS tapes, and those I want, of course, to remain in stereo.
Okay, so it should be 2 channel mono audio.
But, officially, when playing a DVD like this, will it still state sound info as "stereo"? -
Probably. It doesn't know the difference between true stereo and mono that's appearing on both channels.Originally Posted by MheAd
You might be able to select mono input somewhere on your DVD recorder. I recommend this for mono sources. I've had some noise issues when capturing to stereo. -
another idea.
when I do this i usually run the audio through an EQ, that makes the dvd audio much better with source tapes like fan shot concerts!!
Backed up VHS tapes on one DVD, need to create menu DVD
By perceptionist in forum Newbie / General discussionsReplies: 6Last Post: 11th Mar 2011, 18:57 -
transfering VHS to DVD
By Chuck Linn in forum Newbie / General discussionsReplies: 1Last Post: 1st Jan 2011, 11:11 -
Transfering HD mini DV tapes to Dvd keeping the HD quality
By smoore in forum Video ConversionReplies: 9Last Post: 2nd Jun 2009, 11:45 -
trying to convert old vhs tapes to dvd, used sony direct to dvd, not good
By hygieneboy in forum Capturing and VCRReplies: 27Last Post: 4th May 2009, 14:57 -
Screen jitter when transfering from VHS to DVD
By Corey in forum DVD & Blu-ray RecordersReplies: 10Last Post: 31st May 2007, 18:43
