I use TMPGEnc 2.58.44.152 Plus to convert avi to mpg, but the results are a darker picture than the original avi. Why is this can someone explain?
You have just entered the twilight zone of the "dreaded" TMPGEnc option called ---> Output YUV data as Basic YCbCr not CCIR601
As Marlon Brando said:
the horror ...
the horror ...
Don't even attempt to figure out what it means.
All I can suggest is this ... the default for this option is NOT CHECKMARKED so you might want to re-encode but this time put a CHECKMARK on it.
You will find it on the MPEG SETTING dialog box on the TAB called QUANTIZE MATRIX
I found this old post that you might be interested in reading as it is all about that "dreaded" option in TMPGEnc
https://www.videohelp.com/forum/viewtopic.php?t=177532
Good Luck !
This weekend, I gave the "Output YUV data as Basic YCbCr not CCIR601" option a try, prompted by reading this thread. I'm converting DV-AVI from home digital-8 video to Mpeg-2 for DVD.
To my eye, the results are much better with the option enabled. Not only are the colors richer, but the image appears to be sharper. I would definitely encourage experimentation with this option. I did notice that the shadows and some colors appear darker while viewing the resulting mpegs on the computer. But when burned to disk and viewed on a the TV, the darkness seemed less of an issue to me.
How to batch convert mpg to avi
By roberta in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2011, 17:17 -
How Do I convert mpg or avi to vob?
By PHNeedsHelp in forum Authoring (DVD)Replies: 1Last Post: 9th Sep 2009, 14:29 -
[help] TMPGENC DVD AUTHORING v3 - unable to convert to MPG
By meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 05:47 -
How to convert an mpg file to avi
By spyros in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2008, 16:02 -
Need To Convert VOB 16:9 to 4:3 AVI or MPG
By hjordan in forum Video ConversionReplies: 1Last Post: 6th Oct 2007, 22:17
