I just installed the NEC and put in an 8x ridata. Using Nero 6.6 and it says its burning at 8x and the total time should take 7min. After its done though...its really takin 14min. Thats how long i was burnin at 4x w/ my last burner. Is there sumting wrong w/ this drive or what? Im using firmware 2.16.
try posting your problem at the NEC FORUM at cdfreaks.com and check to make sure those 8X RIDATA are actually 8X speed. check to see DMA is enabled.
Use Nero CD-DVD Speed to check your media and d/l fw 2.18: http://club.cdfreaks.com/forumdisplay.php?f=86
i wanted to DL that FW but it said its only for retail versions of the NEC. I bought mine OEM off of newegg...is it still ok?
DVD Burning causes Extremly slow playback
By PowerFalcon in forum DVD RippingReplies: 4Last Post: 27th Aug 2011, 16:47 -
Dvd slow burning
By Psco2007 in forum Authoring (DVD)Replies: 29Last Post: 8th Dec 2010, 16:09 -
slow burning samsung
By doctorrocco in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Jan 2010, 16:26 -
DVD ripping/burning very slow
By happy.hrvat in forum Newbie / General discussionsReplies: 5Last Post: 1st Apr 2008, 18:24 -
lite-on 165p6s, slow copy, good burning?
By troy512 in forum DVD & Blu-ray WritersReplies: 3Last Post: 23rd Oct 2007, 10:13
